I hope this is a simple one as an example might be difficult to provide, I have attached the FC file but it would also require the DB and a couple of PHP files to actually work.
I have been testing the example with Chipfryer for retrieving values from a DB, it does not work for me and in the process of tracking the problem down have I been losing hair.
So the issue appears to be the difference in the string I am getting from the request, according to Wireshark the string is 333 bytes so I increased the Rx string to 350. When I sent the string to a serial terminal I was not getting what I expected so started to play.
Although the string can be 333 characters it appears there is a limit of 255 to what it can send. If I send a string of 255 I get what I expected (although not what I want). If I increase it to 256 I get nothing and if I increase it to 257 I get the first character of the string and so on.
This is the message I am expecting.
HTTP/1.1 200 OK\r\n
X-Powered-By: PHP/5.5.10\r\n
Content-type: text/html\r\n
Transfer-Encoding: Chunked\r\n
Date: Mon, 04 Dec 2023 11:39:39 GMT\r\n
Server: Abyss/2.16.9.1-X1-Win32 AbyssLib/2.16.9.1\r\n
\r\n
[HTTP response 1/1]
[Time since request: 0.250211000 seconds]
[Request in frame: 10]
[Request URI: http://192.168.0.15/request_sensor_a.php?Sensor=FC1]
File Data: 147 bytes
Line-based text data: text/html (13 lines)
88\r\n
<!DOCTYPE HTML>\r\n
<html lang="en">\r\n
<head>\r\n
<meta charset="UTF-8">\r\n
<title>Connect db</title>\r\n
</head>\r\n
<body>\r\n
\r\n
</body>\r\n
</html>FC1=432\r\n
0\r\n
\r\n
This is what I get on my serial terminal at 255.
HTTP/1.1 200 OK
Date: Mon, 04 Dec 2023 18:48:51 GMT
88
<!DOCTYPE HTML>
<html lang="en">
<head>
Length_RX String = 255
When I change the string length to 256. Nothing yet the string shows it is 256.
Length_RX String = 256
If I then change it to 257 the same thing happens except it now prints "H" which is the first character of the message string???
H
Length_RX String = 257
And at 333.
HTTP/1.1 200 OK
Transfer-
Length_RX String = 333
Issue when using SendString from UART
RGV250
- Has thanked: 35 times
- Been thanked: 36 times
Re: Issue when using SendString from UART
Hi,Is the length a byte? This would limit it to 0..255.
FC allows me to create a string with a length of 350, the program shows the captured length of the incoming string is 333 so it seems that there is an issue with SendString with strings longer than 255 which is out of my control.
Bob
- Has thanked: 147 times
- Been thanked: 803 times
It is in the UART component...
Though strings can indeed be larger than this...
void FCD_05481_cal_uart__SendString(MX_CHAR *FCL_DATA, MX_UINT16 FCLsz_DATA)
//Local variable definitions
MX_UINT8 FCL_IDX; // This will limit the size....
MX_UINT8 FCL_LEN;
// .Len = Length$ (.Data)
// .Idx = 0
FCL_LEN = FCI_GETLENGTH(FCL_DATA, FCLsz_DATA);
FCL_IDX = 0;-
Yes - if you look in the wiki most of the components have the source code - but I just looked in the directory for the .c file and checked the code there.
It's easy to replicate the function of SendString to cope with long strings - here I'm relying on the \0 character at the end of the string (I assumed that Length$ might be limited to 255 but didn't check...)
- Has thanked: 529 times
- Been thanked: 719 times
I've been in and changed the variables in the CAL UART and the RS232 components from bytes to UINT to allow more values to be sent and received. Should now be available via the library updates.
Let me know if there are any more outstanding limits like this in place.
- Has thanked: 392 times
- Been thanked: 603 times
That works now and I get the string I was expecting, the code is still not finding the string I am searching for (which I can see in the Rx_String) so I am wondering if the 8 bit circular buffer has a 256 byte limit as well?
Bob
Bob
