Circular buffer max length
RGV250
Has thanked: 46 times
Been thanked: 45 times
Post by RGV250 »
There was an issue with max string length for the uart being limited to 256, I am wondering if the circular buffer has the same limitation as I am getting the string as expected now but the code still does not work. Before I carry on trying to find out where the issue is I would like to know if that has a limit of 256 which could also cause a problem.
Bob
Has thanked: 592 times
Been thanked: 780 times
Re: Circular buffer max length
Hi Bob,
I checked and it looks like there isn't an 8-bit limitation here on the CB or the length of the returned string. You might need to attach your project so we can try and help.
Has thanked: 156 times
Been thanked: 907 times
Post by mnfisher »
If it's the same project as in the UART thread - you have idx as a byte in Parse_Rx which may cause an issue...
Note that you can access characters in a string using .c = .str[.idx] rather using mid$ etc
RGV250
Post by RGV250 »
Thanks for confirming the length is OK.
Thank Martin, I had missed that value.
Still having issues but at least I know it is deeper that that.
Bob
