Create library for the AHT10 sensor
OderlandoRSilva
Has thanked: 4 times
Been thanked: 6 times
Post by OderlandoRSilva »
I am interested in using the AHT10 sensor because it has good resolution and precision and also has a great market price. But I saw that it is not available in the flowcode library. So, I think I'll have to create my own component in flowcode to make it work. Before trying anything, I would like to know if anyone on the forum has tried using this sensor in flowcode before. Any previous experience would be of great help to me. I'm still trying to understand the documentation on how communication with the sensor works.
Has thanked: 234 times
Been thanked: 252 times
Re: Create library for the AHT10 sensor
Hi OderlandoRSilva
Here a info how to modify an existing component and save as an new one.
https://flowcode.co.uk/forums/viewtopic.php?f=3&t=2182
You can also take this opportunity to look at Sensirion's sensors.
These are already supported by Flowcode and are also very accurate.
Different versions are available:
With housing or as demo board or also extremely small on FlexPCB.
Of course you can also have these sensors as SMD parts.
Has thanked: 616 times
Been thanked: 815 times
I've created a new component for the AHT10 sensor now which should be available if you do a full database library update.
Seems to be working well for me but let us know how you get on.
OderlandoRSilva
Hello, Ben and Stefan. I am very grateful for your collaboration. I am very happy about it.
I will test the new component created by ben. I believe it works well for me too.
jgu1
Has thanked: 839 times
Been thanked: 205 times
Flowcode v10 Re: Create library for the AHT10 sensor
Post by jgu1 »
Hi!
I have order some of AHT10, seemed to be an interesting device. Ben have made a component for this device. Meanwhile waiting I try to make a testprogram but is not work in simulation for me. Maybe someone will try to have a look and maybe see what I am do wrong, and please simplifying my program is also velcome :D
Br jorgen
Aht10.fcfx
(14.93 KiB) Downloaded 909 times
OderlandoRSilva
Hello Ben. Would it be possible for you to share the source code of the sensor with us?
Has thanked: 724 times
Been thanked: 783 times
Since the component has been created, an issue was found with the simulation side only.
The component works really well on embedded hardware.
If you would like to try the component (Humidity_AHT10.fcpx) before the update is pushed.
C:\ProgramData\MatrixTSL\FlowcodeV10\Components
If you run any component updates, then the components you added will be overwritten.
I have also attached the updated component source.
Humidity_AHT10.fcfx
(40.17 KiB) Downloaded 694 times
Humidity_AHT10.fcpx
(4.77 KiB) Downloaded 713 times
I've now pushed Martins changes to the update system and also created the component wiki page here: https://www.flowcode.co.uk/wiki/index.p ... ronmental)
jgu1
Post by jgu1 »
Hi Martin & Ben!
Thank you for update. Now my project work in simulation. As soon I receive the sensor I perform a test.
Br Jorgen
Hi Jorgen.
Thanks for letting us know.
I tried to make the simulation as realistic as possible.
E.g. if not added Sample or Initialise, then the simulation should fail to work.
