Create library for the AHT10 sensor
jgu1
Has thanked: 839 times
Been thanked: 205 times
Re: Create library for the AHT10 sensor
Post by jgu1 »
"I tried to make the simulation as realistic as possible.
E.g. if not added Sample or Initialise, then the simulation should fail to work." It work. :D
Perfect Martin Thank´s :)
OderlandoRSilva
Has thanked: 4 times
Been thanked: 6 times
Post by OderlandoRSilva »
The Flowcode team really did a great job. I'm really looking forward to testing the new sensor. I hope one day I can make good contributions to the community too.
jgu1
Post by jgu1 »
"The Flowcode team really did a great job." They always do. :D :D
OderlandoRSilva
I am unable to compile the code for any of the AHT10 functions. The library is updated, but it is not possible to compile.
Has thanked: 724 times
Been thanked: 783 times
Hi.
Many thanks for reporting the issue.
I believe I have resolved the issue.
If you would like to try the component before the update is pushed.
C:\ProgramData\MatrixTSL\FlowcodeV10\Components
If you run any component updates, then the components you added will be overwritten.
Humidity_AHT10.fcpx
(4.78 KiB) Downloaded 490 times
jgu1
Post by jgu1 »
Hi Martin!
I have received the sensors today, I make a test later today and you hear. :D
Jorgen
jgu1
Post by jgu1 »
Hi again!
Just perform a test, for me the AHT10 work perfekt as well in simulation and real world, Martin push your latest version out in the update. :D
I will make some compare with other similar device later.
Thank´s.
Br Jorgen
Aht10.fcfx
(16.23 KiB) Downloaded 586 times
OderlandoRSilva
I tested the sensor with real hardware and it worked very well. Thank you to everyone who contributed to this new hardware in the library. It really has great value for money.
