There appears to be a small bug with the JSON Encoder component. I'm using the encoder to send to a PHP script. I checked the script by sending a string from a browser and I get the expected reply.
If I only have one element the encoder returns (for example) "{\"Name1\":\"Data1\"}" and I can send this off to the PHP script without any problem.
If I encode two elements it returns (for example) "{\"Name1\":\"Data1\", \"Name2\":\"Data2\"}" but this causes issues.
It appears that the problem is when encoding multiple "elements", the component inserts a space after the comma before the next element begins.
If I step through the chart and manually edit the string, e.g. "{\"Name1\":\"Data1\",\"Name2\":\"Data2\"}" removing the space after the comma, then the PHP script happily accepts.
JSON Encoder
- Has thanked: 478 times
- Been thanked: 713 times
kersing
- Has thanked: 81 times
- Been thanked: 65 times
Re: JSON Encoder
Whitespace is allowed within json. However there shouldn’t be backslashes before the double quotes. Valid json looks like this:
Where all quotes should be regular double quotes which the forum software keeps messing with.
See https://www.json.org/json-en.html.
{ “element1name”: “string value”, “element2name”: true,
“element3name”: 3 }See https://www.json.org/json-en.html.
Re: JSON Encoder
The backslashes are added before the quotes automatically by Flowcode, for further transmission and I believe used as an "escape-character".
Sorry if I wasn't clear before.
I have tested the scripts by sending from a browser and everything works as expected. When in Flowcode I create a json string with multiple elements the space is added between each pair which seems to mess things.
If I use the browser and send with or without space I see as expected but in FC with the space I get issues. Removing the space resolves. It sends to the same script as the browser so I am pretty certain it is something within FC.
In the above json is the variable created when FC encodes.
Re: JSON Encoder
Further to the above I created a script echoing as it progresses
Entering into a browser > http://localhost/json1.php?{\"Sensor\":\"FC1\", \"Value\":123} (note: with space)
It first returns the query string > {\%22Sensor\%22:\%22FC1\%22,%20\%22Value\%22:123}
Then runs urldecode giving > {\"Sensor\":\"FC1\", \"Value\":123}
It then runs stripslashes giving > {"Sensor":"FC1", "Value":123}
It then runs json_decode giving > Array ( [Sensor] => FC1 [Value] => 123 )
I can then assign variables giving > Sensor = FC1 and Value = 123
If I omit the space after the comma, I get
{\%22Sensor\%22:\%22FC1\%22,\%22Value\%22:123} (Note: no %20 after comma and no spaces as it progresses)
{\"Sensor\":\"FC1\",\"Value\":123}
{"Sensor":"FC1","Value":123}
I can still assign as before and get > Sensor = FC1 and Value = 123
These values (sent from browser) seem identical to me when decoded so again seems to point at something within FC.
In the script I actually want to access, these variables are then used to update a database. With a space in FC I have problems, no space no issue. Accessing the script using a browser, with or without space has no issue.
Re: JSON Encoder
"Wood" and "Trees" spring immediately to mind... Many thanks
Although the space is entered in the browser it deals with it by adding the %20
turns to
http://localhost/json1.php?{\%22Sensor\ ... ue\%22:123}
I was just playing around with embedded. I suppose most json requests are by POST so this is probably moot.
Thanks again.
turns to
Thanks again.
Re: JSON Encoder
I still feel that adding a space when encoding multiple elements is a bug, as when FC takes this json string for further transmission within FC, the space doesn't get encoded into %20.
kersing
Re: JSON Encoder
Sorry to disagree, the space is not a bug. And putting URL escaped characters in it would break json compatibility and would introduce a bug.
Modifying the URL code to make sure all characters in the URL are properly encoded would be a better solution. Keep in mind there are json use cases that do not use a GET and require proper json. (The backslash encoding of the quotes is already an issue and should (if it isn’t) be a property so it can be switched of for proper json)
Skipping the space on an embedded platform would make sense. One byte less is a significant savings for some controllers. The question is whether json is the right encoding on such controllers.
Re: JSON Encoder
Many basic chips can be "internet enabled" by using devices such as an 8266 and they could create and send a simple string with even the modest of resources and I appreciate that a basic GET string is, in my modest opinion, the most obvious way. There are systems out there though that do accept json as GET so that was what I was trying to achieve. I'm just "playing", no real reason or need other than better understanding.
That is probably what I am eluding to. Within FC, the components are doing all the work (thankfully).Modifying the URL code to make sure all characters in the URL are properly encoded would be a better solution
My aspiration is to have enough embedded knowledge to hold a conversation with you, let alone disagree on a subject. Over the years I have very much appreciated the time you have taken to assist in the forum and I have certainly learned a lot from your contributions.Sorry to disagree
