DHT22 bug ?
kaqkk007
Has thanked: 4 times
Been thanked: 4 times
DHT22 bug ?
Post by kaqkk007 »
Since the latest update, the dht22 component is only willing to produce a 000 value or an incorrect readout , what is the cause ?
Has thanked: 300 times
Been thanked: 465 times
Re: DHT22 bug ?
If you roll back the DHT22 component to an earlier version (via Library Updates), does it work then? Which latest version of the component is working for your project?
Has thanked: 756 times
Been thanked: 819 times
Re: DHT22 bug ?
DHT22 is on our list to be looked into.
Take a look at this post for another temporary solution.
kaqkk007
Re: DHT22 bug ?
Post by kaqkk007 »
I have tried both components (dth22 and grove dth22) and 4-16-20 Mhz quartz frequency as well . The update was done about 2 weeks ago , the project before that worked in simulation and in reality .
kaqkk007
Re: DHT22 bug ?
Post by kaqkk007 »
I have withdrawn the update of the grove DTH22 , will start testing . thank you !
kaqkk007
Re: DHT22 bug ?
Post by kaqkk007 »
What you suggested worked thanks again ! I "upgraded" the sensor component to 17 and the grove dht to 3 and it works.
kaqkk007
Re: DHT22 bug ?
Post by kaqkk007 »
Now I just need to figure out how to display the + - sign of the temperature ?
Has thanked: 175 times
Been thanked: 997 times
Re: DHT22 bug ?
Post by mnfisher »
Found a DHT22 and had a play. Wired up to an esp32 and an oscilloscope - interesting trace!
I couldn't understand why pulling the pin low for 3ms (actually this only needs to be 1ms) would start a 'sensor' reading in the component - but my pulling a pin low for a period didn't (just a low for 3ms) I didn't get a reading using the component though - and wasn't sure why.
So - a little time later - I came up with this. Tested and working on an esp32 - it uses a slightly different approach to the component (making the code slightly simpler?) I also time in 10us lumps - making the delays slightly more achievable for some MCUs..
If anyone would like a play...
dht22.fcfx
(22.77 KiB) Downloaded 1046 times
It's not a component (sorry) - and Temp and Humidity are saved as 10 times the actual value (so currently displaying 12.8C and 64.3% humidity which are saved as 128 and 643)
As an aside - if there is a timeout error - and less than 40 bits are received - it is necessary to check that there isn't an error before calculating temp - otherwise there is a compilation error (data may be used uninitialised) - that compiler is very neat!
Re: DHT22 bug ?
Post by mnfisher »
Sample output from a DHt22.
kaqkk007
Re: DHT22 bug ?
Post by kaqkk007 »
At DHT22, what is the trick to tell if the temperature is in the - or + range ?
