There is no option for setting the path in the ConnectTo property of the MQTT_Client component.
niedian
Has thanked: 3 times
Been thanked: 5 times
Flowcode v10 There is no option for setting the path in the ConnectTo property of the MQTT_Client component.
Post by niedian »
When using the MQTT component of ESP32-S3 to connect to "https://www.emqx.com" using the WebSocket TLS/SSL port 8084, EMQX requires the connection path. However, there is no option for setting the path in the ConnectTo property of the MQTT_Client component. How should I handle this? Greetings!
The connection address for EMQX is:
https://docs.emqx.com/en/cloud/latest/c ... mqttx.html
niedian
Re: There is no option for setting the path in the ConnectTo property of the MQTT_Client component.
Post by niedian »
"path:"
Has thanked: 291 times
Been thanked: 458 times
I think this component uses the MQTT / TCP protocol and requires you to use port 1883 or 8883. 8083 and 8084 are the ports used for the WebSocket protocol.
niedian
Post by niedian »
FLOWCODE official, can you provide an example using MQTT_Client to connect to "https://www.emqx.com/" (free version)? I have been trying for a long time with ESP32-S3, but still couldn't establish the connection to "https://www.emqx.com/". I hope FLOWCODE can provide an example. Thank you!
niedian
Post by niedian »
"Serverless"
niedian
Post by niedian »
https://www.emqx.com/“(Serverless)
Has thanked: 442 times
Been thanked: 661 times
Post by chipfryer27 »
Half way down this link you get connection information
https://www.emqx.com/en/blog/the-easies ... -with-mqtt
Notably :-
Free public MQTT broker
In this post, we will use the free public MQTT broker provided by EMQ, created based on the fully managed MQTT cloud service - EMQX Cloud. The server information is as follows.
Broker Address: broker.emqx.io
TCP Port: 1883
WebSocket Port: 8083
It also gives examples of subscribing and publishing. Have you tried any of them?
EDIT
Forgot to include this link too
https://www.emqx.com/en/mqtt-guide
If you are using the MQTT Client component in an embedded device then you need to be using port 1883 (http) or 8883 (https). These are the TCP ports. If you are using Flowcode Web Developer, then you should use the WebSocket ports instead.
You will need to set your username and password to the ones you have set up on that EMQX site if you are using their service. Their free MQTT broker may may not need these credentials.
niedian
Post by niedian »
I'll give it a try, thank you! Regards!
