I'm not sure I understand your question.The sensor can obtain readings that are string based and also float, which are +/- assigned and these are easily displayed on a LCD (for example).
DHT22 bug ?
- Has thanked: 404 times
- Been thanked: 624 times
Re: DHT22 bug ?
Unlikely.
Most likely when you changed chips the pin connections aren't correct or the oscillator settings are wrong.
If you post your 16F876 file I can have a look.
Unlikely.
Re: DHT22 bug ?
The footprint is the same between the 18f252 and the 16f 876 , the difference with the oscillator is that I use the 252 with 10Mhz quartz and 4 internal multiplication at 40Mhz , and the 16f's counterpart can only be used up to 20 Mhz . The last update I set the dht probe from 4 to 3 and the probe pack from 18 to 17 so it worked with the 252 , but the 16f constantly CRC error . I also tried to stop the interrupt before starting the measurement and then restarted , but it did not help either
Re: DHT22 bug ?
If the component is the same (at same version) and works on one chip but not another, it could possibly be something with the chip or maybe timings. The timings can be an issue with that sensor.
To see if it can communicate, have you tried changing the Use Checksum in the component properties to No?
