ESP-IdF V5.12 problem
Has thanked: 245 times
Been thanked: 256 times
Hi to all
I have removed Python 3.7 installed Python 3.12
it's found Python 3.12
it's not found requirements...
Flowcode can not found....
============================== Toolchain Check ==============================
ERROR: Python is not installed
git version 2.21.0.windows.1
ESP toolchain found at "C:\Users\Kfs-Forschung\Desktop\esp-idf\"
Building: C3_24_1 ...
IDF Version: v5.1.2 ...
Error: The following tools are not installed in your environment.
but if I type python it should show me Python 3.12
C:\Users\Kfs-Forschung\.espressif\frameworks\esp-idf-v5.1.2>python
Python 3.11.2 (tags/v3.11.2:878ead1, Feb 7 2023, 16:38:35) [MSC v.1934 64 bit (AMD64)] on win32
Type "help", "copyright", "credits" or "license" for more information.
Has thanked: 752 times
Been thanked: 814 times
Re: ESP-IdF V5.12 problem
Hi Stefan.
If it was me seeing that message, I would uninstall ESP-IDF and python.
Make sure both esp-idf & esp-idf-tools directories are deleted and start from fresh following the guide here.
It has not let me down to date.
I would also stick to Python 3.7
Hi Martin
Yes I installed Python 3.7 again and selected it by the setup. And now it's working again.
Sooner or later we will have to change Python version and i suspect the problem is just in the toolchain check
The effort is small and makes it possible to programme the ESP32 C3 and ESP32 S3 with Flowcode. Who knows, maybe BLE.... will follow
https://docs.espressif.com/projects/esp ... setup.html
Has thanked: 466 times
Been thanked: 696 times
Post by chipfryer27 »
Hi Stefan
As per this post
viewtopic.php?p=14187#p14187
I'm now running idf v5.1.2 and python 3.11 on a W10 machine. Other than compiling a basic flasher to hex I've not had a chance to do much with it.
Hi Lain
Yes idf v5.1.2 and Python 3.11 worked for the new ESP32 S3 and ESP32 C3.
But I had problems with the "old" ESP32. I could no longer configure Bluetooth. So I had to use Python 3.7 again.
I've not had a chance to do anything regarding "radio" using v5.1 etc but hope to this week using older and newer ESP's. I'll update once done.
Hi to All
I am still having problems with the changeover to ESP -IDF 5.12.
The problems are not the new ESP32 C3 or S3 versions but the "old" ESP32
One of the problems, I cannot open the menu to setup Bluetooth.
It is also not clear to me whether I should work now with Python 3.12 or 3.7.
Fail Message when I want to open the menu:
menue.txt
(2.96 KiB) Downloaded 956 times
kersing
Has thanked: 81 times
Been thanked: 65 times
Post by kersing »
There are known compatibility issues between Python 3.11 and 3.12, perhaps you can try 3.11?
Hi Kersing
Ok the menue open now with Python 3.11 and I can config bluetooth again.
The menue looks new....
But now I can not compile anymore
Error.txt
(4.03 KiB) Downloaded 1025 times
Hi Stefan.
Try deleting the current build files which are located in a folder next to your Flowcode project file with the same name.
Or you could just rename the folder.
