Hi Ben and all of the team,
can you please add support for the Digi Pot AD5280 / 5282?
Thank you very much
Dirk
Digi Pot AD5280
DirkB
- Has thanked: 1 time
- Been thanked: 4 times
- Has thanked: 607 times
- Been thanked: 803 times
Re: Digi Pot AD5280
Hi Dirk,
We're looking into it for you.
- Has thanked: 713 times
- Been thanked: 775 times
Re: Digi Pot AD5280
Hi Dirk.
I have created the digital pot component for you.
I have not got the hardware to check its working.
Can you let me know if it works, please?
Place the attached component.
If you run any component updates, then the component you added will be overwritten.
C:\ProgramData\MatrixTSL\FlowcodeV10\ComponentsIf Flowcode is already open, then you will need to reload your project for the new component to work
- AD528X.fcpx
- (5.46 KiB) Downloaded 781 times
Re: Digi Pot AD5280
Hello Martin,
the ADS5280 has 2 additional port outputs, the AD5282 has one additional port output.
Is it possible to add these functions to the component? I will now be able to test the component,
unfortunately I haven't had a chip yet and unfortunately don't have the time.
Thank you
Dirk
Thank you
Dirk
