Morning,
When placing a text block on the 2D dash how do you resize it ?
You used to be able to drag the bottom corner and move accordingly
app developer - text block on dash board
steve001
- Has thanked: 81 times
- Been thanked: 30 times
- Has thanked: 724 times
- Been thanked: 783 times
Re: app developer - text block on dash board
Hi Steve, that has not changed, you still can.
Just make sure scale (Green highlighted box) is selected.
Then you can drag the text/component corners ,as shown.
Did you know that if you use Static Text instead ,you can dynamically change the contents, colour and size during simulation?
For example the values in C colours change depending on the setting as temperature measured.
If that is something you are interested in can help you further.
