USB serial(PIC18LF14K50) not working.
electronick
Has thanked: 8 times
Re: USB serial(PIC18LF14K50) not working.
Post by electronick »
Hi Steve.
The info about the high speed USB did the trick, but I had to put an external 1k5(as mentioned in the datasheet) pullup on D+ to make it work properly and for the MCU to be identified as an high speed device.
As for the osccon settings, there are still one choice, bit 8-11 that has a choice that I belive doesn´t belong there.
My speed setting for the project is set as in the example above.
Thank you very much for your help Steve :-)
Best regards
Nick
Has thanked: 264 times
Been thanked: 424 times
Great news. Thanks for letting us know.
