Bluetooth after installing ESP IDF 5.x
MJU20
Has thanked: 105 times
Been thanked: 76 times
Flowcode v10 Bluetooth after installing ESP IDF 5.x
Post by MJU20 »
I've installed the latest toolchain for the ESP IDF and tried to use the ESP_BT example on this page:
https://www.flowcode.co.uk/wiki/index.p ... (Wireless) on a ESP_WROOM-32 board.
Changed the settings for the Bluetooth to enable classic BT and SPP:
Flashed it, but nowhere a new Bluetooth device available (BT via PC and smartphone).
What is wrong?
Has thanked: 234 times
Been thanked: 252 times
Re: Bluetooth after installing ESP IDF 5.x
Hi MJU20
I had the same problem, but no solution yet. Just back to Phyton 3.7..
But the BT still does not work. When I search with the PC or Iphone, Bt it finds nothing.
https://flowcode.co.uk/forums/viewtopic ... 9&start=10
MJU20
Post by MJU20 »
Too bad that such things should happen when they are supposed to make things better.
I really hope that these issues are addressed as soon as possible.
This is a result of trying to add more ESP32 chips by upgrading the ESP IDF?
