I'm working on a sizeable project with six UART ports, with much time expended to check and prove configurations (etc) without conflicts.
However, in addition to the six hardware UARTs, I've added a 7th software 'UART' (Tx only) to drive a Parallax LCD display.
A few times now I've re-opened and re-built the Hex, but threw up an issue with the LCD display and conflicts with one of the hardware ports.
Investigations revealed that the nominated software UART Tx port pin of the LCD (C13 in my case) reverts to A2 every time I re-open the project, so I have to manually reinstate the port setting every time after opening, before compiling the image.
Many thanks,
Brendan
Unexpected changes to FC10 source project on re-opening
Brendan
- Has thanked: 64 times
- Been thanked: 17 times
- Has thanked: 575 times
- Been thanked: 757 times
Re: Unexpected changes to FC10 source project on re-opening
Hi Brendan,
Is this still the case after applying the latest library updates. We have just tacked a bug like this for SPI and rolled the fix out to everything potentially effected, SPI, I2C, UART. If the updates doesn't solve the problem then please can you attach a simple project that shows the problem and we will investigate.
Hi Ben.
Many thanks for the heads-up.
I've just updated the affected work laptop (3 component updates) and very happy to confirm that the project now preserves the software UART configuration after closure and re-opening
Best regards,
Brendan
Best regards,
Brendan
