Any Pin Interrupt
Amrat
Has thanked: 1 time
Any Pin Interrupt
Post by Amrat »
How can I use any Pin for Interrupt ?
Thanks for help
Amrat
LeighM
Has thanked: 98 times
Been thanked: 294 times
Re: Any Pin Interrupt
Post by LeighM »
Use the Flowcode Interrupt icon
Add it once at the start of your main program.
It has properties where you set the input pin to be used, and the macro to call when the interrupt occurs.
Amrat
Has thanked: 1 time
Post by Amrat »
Thanks.
But I mean normally I can use INT0 INT1 or other interruot shown in drop list.
But I want to use other Pin, ie D4 but I cant make it work !!
Any suggestion ?
Thanks again
Amrat
Has thanked: 156 times
Been thanked: 907 times
Post by mnfisher »
Which MCU are you using. Some, such as the Atmega 328p in the Arduino only have hardware interrupts on specific pins.
Other MCUs allow more pins to be used - look up custom interrupt in the Wiki.
There is an Arduino library that mimics interrupts on any pin - but this just checks the pin state regularly and calls a function of it has changed - it isn't a true interrupt.
Has thanked: 429 times
Been thanked: 647 times
Post by chipfryer27 »
Following on from Martin, the WiKi has some examples that may further assist
https://www.flowcode.co.uk/wiki/index.p ... Interrupts
jgu1
Has thanked: 814 times
Been thanked: 203 times
Post by jgu1 »
Hi Amrat!
Try first Martin´s advice. (he is the best ;) )
Another way I used for time ago, I use the Interrupt Timer. I have made a small testprogram you can look at, only test in simulation.
The interrupt timer check if any input or "something happend". But from experience and from all the very good programmer here in forum (ok Martin, Chipfreyr :lol: ) Don´t use delay´s or other component macro in the user macro called from the Interrupt timer, only flags, read input and counter ect.
Maybe my little examble could help you a little or ideas? :)
Br jorgen
Multi_Interrupt_Interrupt.fcfx
(20.42 KiB) Downloaded 448 times
Amrat
Has thanked: 1 time
Post by Amrat »
Dear All,
Thanks sincerely for sparing holiday time to reply. I am grateful and now I understand well.
Thanks again
Amrat
