State Machine Breaks working Web App
CactCat
Been thanked: 1 time
Post by CactCat »
I am trying to add a state machine to an existing Web App. The addition of a State Machine macro causes the Web App to no longer function even though the added State Machine is not called/executed. The page will load and the buttons and switches will toggle but the previously working flow chart macros no longer execute. I also tried calling the macro from a timer with the same result.
best regards,
jj
Has thanked: 311 times
Been thanked: 479 times
Re: State Machine Breaks working Web App
Thanks for pointing this out. To confirm - Web Developer does not support the use of State Diagrams. I will change Flowcode so that State Diagrams are not an option when designing web apps.
CactCat
Post by CactCat »
Would state machines work in PC App?
If so is there an easy way to make a Web App into a PC app?
State Diagrams work fine in PC Developer apps. But there is no wat to convert between PC and Web Developer apps.
