Morning all
I have been using the PIC18F47K40 and have had the SD card working without a problem. On changing to the PIC18F47K42 the SD card does not pass the initialise component macro.
The code is identical between the two devices mentioned as are the pins, the clock frequency, the initial pre-scaler and the high speed pre-scaler.
The clock at the time of the card initialisation is 8 meg and the pre-scaler is f/64 which gives 125kHz to the card.
I have checked that all other pins used have been correctly allocated and have seen this problem on more than one PIC18F47K42
Any ideas?
Thanks Howard
FC9
SD card not initialising using 18F47K42 FC9
howard123
- Has thanked: 1 time
- Has thanked: 786 times
- Been thanked: 844 times
Re: SD card not initialising using 18F47K42 FC9
Are you referring to a compiler error with just initialise, if so can you post your .fcfx, .c and .msg.txt files please.
Or are you referring to stuck on initialise within your hardware?
Hello Martin
The hardware hangs at the point of initialisation.
I have done a sanity check by going back to the PIC18F47K40 and this does initialise and record in the main loop, using the same SD card.
In that case can you try software mode instead.
The issue with 18FxxK42 devices is some of the SFR are different to the norm, so they are not currently supported with SPI or I2C.
The rules have been completely rewritten!
Sorry for any inconvenience.
Thanks I will give that a go and let you know if it works.
Again thanks, this has worked. Some points to note are that on this chip when using the software I2C the slew rate control must be on and when using the software SPI the slew rate control must be off.
