Thank you !
Now I've reinstalled everything after deinstalling.
I can see the an esp-idf folder on my Desktop, but the esp-idf-tools folder I don't find anywhere.
In the App list there is an App called ESP-IDF Tools 2.3
According to the ESP-IDF Command Prompt everything should be o.k. but I always get the message while sending the program to the target that the Toolchain is not installed.
How can I send you my PrintScreen Images ?
Thanks for help
ESP 32 Toolchain problem
felixegger
- Been thanked: 2 times
- Has thanked: 634 times
- Been thanked: 840 times
Re: ESP 32 Toolchain problem
Are you pointing to the toolchain in Flowcode using the View -> Global Settings -> Locations,
The ESP path should contain the path to your esp-idf installation.
- Has thanked: 245 times
- Been thanked: 257 times
Hi Felix
Get the screen with snipping tool from windows and safe it. Press Attachments and add the file.
Are you using win10 ?
In English?
FC9 in English?
In English?
FC9 in English?
felixegger
Thank you Stefan
Windows 10 I use in German
Flowcode 9 I use in English
Now while I'm reinstalling the ESP 32 Toolchain, I will document every step
- B1.png (39.69 KiB) Viewed 12898 times
felixegger
felixegger
3 rd step
Download ESP IDF
4 th step
v4.2 (release version)
5 th step
C:\Users\maestro\espressiv
6 th step
All three additional tasks selected
Download ESP IDF
4 th step
5 th step
6 th step
- p.erasmus
- Has thanked: 104 times
- Been thanked: 88 times
HI
ENTER the PATH s shown below in yourself by hand and make sure at the end it will install in these location
I had to do this !!
For the tools it does not create the esp-idf-tools folder automatically force it by entering it yourself
before you select install capture the locations it will install the esp- idf and the esp-idf-Tools also print the sceen for use as help here,
ALSO make sure the locations is as you enter in the brows section
I had to do this !!
felixegger
- p.erasmus
You have the same problem I had
as long as it install the tools in essprif and
NOT esp-idf-tools it did not work with me ,I mentioned force it to C\:esp-idf-tools by entering the path your self in the brows section
look at the screen shots earlier -I posted it will help
felixegger
