ESP 32 Toolchain problem
felixegger
- Been thanked: 2 times
Re: ESP 32 Toolchain problem
my new Command Prompt
- K.png (377.68 KiB) Viewed 13483 times
felixegger
Unfortunately still this message appears:
I will also study these new messages which came in between
- L.png (67.97 KiB) Viewed 13481 times
- Has thanked: 300 times
- Been thanked: 468 times
You need to 'point' Flowcode at the ESP toolchain location. Open Flowcode and set it in the "Locations" tab of "Global Properties".
- Has thanked: 245 times
- Been thanked: 257 times
felixegger
Thank you Stefan
Now I'm one step further. The Toolchain was installed now.
Is that correct, that I can't send my program to my ESP 32 for licences reasons as the following message shows ?
Felix
Felix
- T1.png (171.68 KiB) Viewed 13474 times
felixegger
After several trials I'm getting now the following message, although my ESP 32 was connected properly :
- U.png (88.88 KiB) Viewed 13474 times
- Has thanked: 634 times
- Been thanked: 840 times
Ok it sounds like the toolchain is now setup correctly and Flowcode is pointed at it correctly but your program is generating an error.
Please can you attach your .fcfx program file and we will have a look at what is causing the compilation error for you.
felixegger
The ESP toolchain is very picky about correct syntax and likes to treat a lot of warnings as errors. The Flowcode simulation is very good but will not pick up and trap all the errors that the compiler will.
Please upload your file and we will investigate the cause of the problem.
felixegger
My file is very simple and it looks like this.
Otherwise I don't know how to upload my fcfx program to you.
I'm using a ESP32 WROOM 32
- pcode.png (80.97 KiB) Viewed 13455 times
