STM32 Increase Uart RX buffer size
Alan_37
Has thanked: 57 times
Been thanked: 28 times
Post by Alan_37 »
I am trying to send a 256Byte serial data to write 1 page of W25 flash
but is seems that the max number of bytes I can receive is 255, I think is the Uart RX buffer Size
that is limiting this , is there a way to increase the RX buffer size ?
Tried the following but dose not work
HAL_UART_DeInit(&MX_UART_NUMBER_1);
MX_UART_NUMBER_1.Init.RxSize = 280;
HAL_UART_Init(&MX_UART_NUMBER_1);
Has thanked: 442 times
Been thanked: 661 times
Re: STM32 Increase Uart RX buffer size
Post by chipfryer27 »
Would the circular buffer be of use?
Usually I use the RxINT to grab a byte and immediately store in the buffer for processing within the Main loop.
Just a thought.
Alan_37
Post by Alan_37 »
Hi chipfryer27,
Thanks for your reply
I am using a circular buffer, have set number of bytes to 260
have also tested the buffer it can hold 260 bytes so buffer is not the issue .
I am still not 100% sure it is the RX buffer :idea: maybe I try Uart in software mode
that should eliminate the hardware buffer
Alan_37
Post by Alan_37 »
Found it ,
Was not the RX Buffer , I was trying to get the circular buffer size into a byte variable
which 255 is the max .
Jeez, that was kinda stupid :lol:
Thanks again
Reagrds
