SR04 Ultrasonic Sensor
Has thanked: 444 times
Been thanked: 665 times
Re: SR04 Ultrasonic Sensor
Post by chipfryer27 »
Following on from the above.
This time I used the same setup as documented in the above posts but using software mode with the following results
Measured (cm) / Displayed (cm) / Pulse Width (mS)
109 / 78 / 6.27462
120 / 86 / 6.9197
140 / 100 / 8.0691
144 / 103 / 8.32248
162 / 116 / 9.3676
I have only attached the shot from 162
Has thanked: 724 times
Been thanked: 783 times
Flowcode v10 Re: SR04 Ultrasonic Sensor
Hi Iain
I have just looked into this, and its not a bug but a setting in which I gave incorrect advice.
What I have done is exposed the timer rollover time which is in seconds
The furthest distance that can be measured is 310 cm = 18ms.
Therefore, the value exposed can't be below the maximum ms time.
If using a clock speed of 32MHz, then you will need to set the prescaler to 1:4.
Timer Rollover time.png (10.24 KiB) Viewed 4954 times
That gives a maximum time of 32ms which is ample.
Rollover time needs to be a low as possible but higher than the ms max distance time (e.g 18ms).
To try the component.
C:\ProgramData\MatrixTSL\FlowcodeV10\Components
Place the attached component.
HC_SR04_Ultrasonic.fcpx
(4.87 KiB) Downloaded 533 times
Hi Martin
Thanks for that. I'll try as soon as I can and get back to you.
Hi Martin
Just did a quick test, not much time. Downloaded and set Prescaler 1:4
Measured (cm) / Read (cm)
162 / 160
187 / 180
213 / 211
Looking very good so far... :)
I'll do some more tests later but things seem sorted now.
Thanks again.
