Calculation Command Icon bug [SOLVED]
Sasi
Has thanked: 43 times
Been thanked: 15 times
Flowcode v10 Calculation Command Icon bug [SOLVED]
Post by Sasi »
I noticed an interesting phenomenon with the calculation icon.
If I write a relatively large amount of operations in the Calculations window, after saving and reloading the *.fcfx file, the operations to be performed are not visible by clicking the Calculation icon, but they are included in the program when the program is compiled. .
I have attached an example that works like this for me.
Sasi
Calculation_Bug_prg.fcfx
(8.37 KiB) Downloaded 661 times
kersing
Has thanked: 81 times
Been thanked: 65 times
Re: Calculation Command Icon bug
Post by kersing »
Is the first line of the calculation empty? If so make sure there is either a comment or a calculation.
Has thanked: 647 times
Been thanked: 856 times
This should work correctly. I opened the source code in a text editor and got rid of the initial blank line in the calculation icon.
(8.35 KiB) Downloaded 839 times
Hopefully we get this resolved soon.
Sasi
Post by Sasi »
I didn't think that was the source of the problem.
Thanks for the help.
Sasi
Has thanked: 795 times
Been thanked: 858 times
Re: Calculation Command Icon bug [SOLVED]
The issue and work around was reported here
jgu1
Has thanked: 910 times
Been thanked: 220 times
Post by jgu1 »
Hi Martin!
What happend if we open an older project, will all the calculation the dissapear to, or is it only in new project?
I dare not to open anything at the moment :o
Jorgen
Has thanked: 311 times
Been thanked: 479 times
The calculations only disappear if the calculation icon is opened and then OK is pressed.
If you notice a project which has this problem, then send it to me (via PM) and I will fix it. Or you might be able to edit the file directly in a text editor and remove the blank line(s) or add "//" to the top of the problem calculation statements.
jgu1
Post by jgu1 »
Hi Steve!
Thank you. ;)
Jorgen
