Posts: 2333 Joined: Mon Dec 07, 2020 10:06 am
Has thanked: 647 times
Been thanked: 856 times
Post
by BenR » Wed Jun 05, 2024 10:19 am
Many thanks for the suggestion, it looks fairly straightforward. I've ordered one to have a go.
Post
by BenR » Fri Jun 07, 2024 12:23 pm
I've now added the component for this to the library updates.
It's available from Sensors -> Magnetic.
It's working well via my API interface board but I haven't tested with hardware so if you have a go then let us know how you get on.
celebriums
Posts: 52 Joined: Fri Dec 18, 2020 7:33 am
Has thanked: 25 times
Been thanked: 13 times
Post
by celebriums » Sat Jun 08, 2024 11:05 am
Thanks Dear Ben
I will try this component as soon as possible.
Sadık Süme
celebriums
Post
by celebriums » Thu Mar 13, 2025 9:18 am
Hello Ben
I would like to say that this hardware works, but I can't find this driver in Flowcode 10 and Flowcode 9 libraries. Can you add it again.
Sadık Süme
Posts: 2477 Joined: Wed Dec 02, 2020 11:07 pm
Has thanked: 795 times
Been thanked: 858 times
Post
by medelec35 » Thu Mar 13, 2025 9:30 am
It is already in FC10 libraries:
Make sure you have all the latest components by using the Library update.
Change Files in-use to Full database.
Then select the Components ribbon, and then the magnifying glass.
Enter as5
It has not been added to FC9 libraries.
celebriums
Post
by celebriums » Thu Mar 13, 2025 1:44 pm
Hello Dear Martin, thank you very much for your reply.
I found the error. Because I installed the program for the first time, it doesn't install the component until I tell it to do a full update. When I told it to do a full update, it installed the component.
Thank you very much
Sadık Süme
Sadık Süme
