MODBUS SLAVE UNDER IT ?
Marc-Lepage-AIF
- Been thanked: 1 time
I use this function to establish communication with a network of charging stations. The function is call in "pooling mode" and is currently unstable. It would be better to have it working under IT. Is it possible to have it that way? Thank's for your answer.
- Has thanked: 615 times
- Been thanked: 807 times
Re: MODBUS SLAVE UNDER IT ?
Sorry I'm not sure what you mean by under IT?
- Has thanked: 441 times
- Been thanked: 656 times
Marc-Lepage-AIF
HI,
Why not... But it looks like it would be the same as for Modbus under Slave (RTU). As I see in the available IT function whatever MODBUS is used the is no IT possibilities.
When the Master is pooling, the Slaves can be doing something else than listening to the bus , the pooling function could stay stuck for a while ... of course you can add a timer or a watchdog or both but then you loose fluidity...
This is why i would like the Slave function under IT.
Marc-Lepage-AIF
HI Ben,
