can add a camera component and a face recognition component?
niedian
- Has thanked: 3 times
- Been thanked: 5 times
Hello, is it possible to add a camera component and face recognition component? I saw in the ESP32 documentation that it has face recognition capability.
- Has thanked: 177 times
- Been thanked: 1026 times
Re: can add a camera component and a face recognition component?
I posted a bit about using the camera a while ago (see viewtopic.php?f=3&t=1679&hilit=Camera -)
Yesterday I finally managed to add a component to a flowcode program the espressif way - though it is not for the faint of heart..
I am using the espressif tools v5.1.1
Create a FC program and compile it to create the directory structure.
Open a esp cmd prompt. Cd to your program directory (so if your program is test.fcfx this will be cd test)
With the component there will be a "idf. py add-dependency component" copy this and run at the command prompt.
Next add to your program supplementary code #import <component.h> - you'll need to find the correct header file name (look in the examples)
Now force a recompile - at your command prompt do idf.py fullclean and then recompile from fc.. (this needs to be a full rebuild of the program)
Now you should be able to use the component with a little C glue code - take a look at the examples and in a code block use the appropriate functions. Use long ints and casts for pointers
For example;
FCV_PTR = (mx_uint32) initialise(params)
It is (fairly) easy to write some interface functions (most will be a few lines of C) though it depends on the component.
Note that some components also add to the config (the camera will do this) - look using idf.py menuconfig
See https://components.espressif.com/ for available components
Good luck
For example;
Good luck
I created an example 'camera'
Compile
cd camera
idf.py add-dependency "espressif/esp32-camera^2.0.9"
add #include "esp_camera.h" to supplementary code (and save)
idf.py fullclean
re-compile
You should find a 'managed_components' directory (including examples)
idf.py menuconfig
-- components -> camera (select camera model(s) etc)
Compile
cd camera
idf.py fullclean
re-compile
idf.py menuconfig
