Esp 32 using HC-SR04 PROBLEM
daddytims_tims
Has thanked: 125 times
Been thanked: 13 times
Flowcode v10 Esp 32 using HC-SR04 PROBLEM
Post by daddytims_tims »
Hi All
I am currently working on SR04 project that requires an esp32.
It works with the Pic18f1320 and Pic16F648A.
However, I am not getting any readings, when using the esp32 with the Sr04. it ONLY return 9999.
How can this be resolved?
I need some assistance as it regards to this project.
I attached an example file below
Esp32_HcSr04.fcfx
(12.93 KiB) Downloaded 386 times
Has thanked: 729 times
Been thanked: 785 times
Re: Esp 32 using HC-SR04 PROBLEM
The properties Use Timer Interrupt, have you tried selecting No instead of yes?
The timer for ESP32 will be investigated.
Thank you for letting us know.
daddytims_tims
Goodmorning All
Hi martin
No, I didn't select "No", but I just did, another test with 'NO' and the result were 1 then it jumps back to 9999
ryan
daddytims_tims
Goodmorning Team
Any updates on the TIMER FOR THE ESP32?
I haven't got back any Response as yet.
Sorry for the delay.
It is on my Todo list, and it will be investigated soon.
daddytims_tims
Goodmorning.
Any update on this topic?
Am still interested in using the esp32 with the hc sr04
I'm currently looking into this now.
It's working for me on ESP32 with Use Timer = Yes.
HC SR06 Test1.png (43.39 KiB) Viewed 8057 times
AS the distance measured is 5.5cm, I would expect the result to be between 5 & 6
daddytims_tims
Re: Esp 32 using HC-SR04 Working
Hi Medelec35
Thanks a lot, my Hc-SR04 is now working with the esp32
:D :D
I can now finish up my Project.
That's great to hear.
Thank you for the update.
