App Developer - Console Text Viewer Functions
jay_dee
Has thanked: 101 times
Been thanked: 72 times
Post by jay_dee »
Hi, These requests are specifically for the ConsoleTextViewer, for use on App Dev 2D Panels but I assume it is driven by the Console features.
In addition to the current Console Write functions, are any of these possible?
Set active Line
Set Cursor Position in Line.
Write Text at current Cursor Position.
Clear Specific Whole Line.
Clear from Cursor Position to End of line.
Clear from Cursor Position to Start of line.
Clear X Characters from Cursor Position.
This could create a powerful tool for sending messages and variable to a user defineable text menu, like a simplified VT100.
Alternative approach would be an App Dev 2D Panel version of a traditional LCD or GLCD Component, with user definable Rows and Columns.
Certainly not 5 Minutes work I am sure but very handy for Add Dev users! :)
J.
Has thanked: 629 times
Been thanked: 836 times
Re: App Developer - Console Text Viewer Functions
I've made a start on adding these functions into the console writer component. Hopefully shouldn't take long to complete.
jay_dee
Post by jay_dee »
Thanks Ben,
Outputing simple text strings works pretty well for me as a Field diagnostic feature. I think it was Martin who put me onto VT100
Integrating a simple subset of this with App Dev, could look pretty nifty!
I look forward to any progress you can make.
This was last week, using my current serial diagnostics for monitoring a couple of custom projects to solve a problem for a customer, using Pi PICOs to do some CAN juggling!
VT100 (Medium).jpg (111.33 KiB) Viewed 10874 times
At the customer (Medium).jpg (124.36 KiB) Viewed 10874 times
Has thanked: 755 times
Been thanked: 817 times
jay_dee wrote:
Tue Jul 02, 2024 12:45 pm
Ah, yes I remember that post well.
It's a shane the VT100 link does not work and images are missing.
What a great setup you have there!
Ooh yes that looks like a brilliant setup :D thanks for sharing. What type of car is that?
I've completed the component additions and added the suggested functionality using the macro names shown below.
Set active Line - SetCursorPosition
Set Cursor Position in Line - SetCursorPosition
Write Text at current Cursor Position - AddStringAtCursor
Clear Specific Whole Line - ClearLine
Clear from Cursor Position to End of line - ClearFromCursorToLineEnd
Clear from Cursor Position to Start of line - ClearFromLineStartToCursor
Clear X Characters from Cursor Position - ClearXCharsFromCursorPosition
I've given it a quick test and it seems to be working but I haven't gone to town in terms of error checking so let me know if you find anything.
The up to date wiki page is here: https://www.flowcode.co.uk/wiki/index.p ... ndicators)
jay_dee
Post by jay_dee »
Thanks Ben, I'll have a play!!
Customer project car...as ever I'm covered by NDA's but its fair to say it will be making its first public appearance at Goodwood festival of speed. I think its a chunk above a mil! Trust me, there are lot of little FC based problem solvers running around in Racecars, Hypercars and LeMans 24H... :) J.
jay_dee
Post by jay_dee »
Maybe I'm doing something silly or miss interpreted its use. Started to create a basic menu in PC App Dev but not able to get anything to display on the ConsoleTextViewer when running as a simulation or as a deplyed app.
I linked ConsoleTextViewer to ConsoleWriter.
I have refreshed the database, restarted FC.
Console_Test_V2.fcsx
(17.66 KiB) Downloaded 485 times
Investigating for you now.
It seems to work if you fist do an AddString to initially add the data and then you can cursor around. I'll see if I can also make it work how you're trying to use it.
Hi J.
Out of curiosity, have you seen this web page?
Hello again,
Right hopefully should work much better now.
If you want a fixed width font such as your values all appearing lined up then I've also added the ability for the console viewer to change the font and so you will be able to change the font to a fixed width font such as courier new.
Unfortunatley the text field isn't able to replicate the console window colours. If you need colours then you will have to use the console window for now.
