C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\PIC\batch\pic_xc8_comp.bat reported error code 0x1
daddytims_tims
Has thanked: 125 times
Been thanked: 13 times
Post by daddytims_tims »
Hi everyone
I am trying to create a Project using the pic18f2420/ as well as the 18f2321.but first
I decide to try a compile a simple 1 sec flash program, however it's not compiling.
How can I resolve these issues?
I attached the message as well as the 2 projects
How can I resolve this Problem.
Please and thank you.
Pic18F2420.fcfx
(9.34 KiB) Downloaded 231 times
Pic18F2321_Test.fcfx
(9.27 KiB) Downloaded 230 times
Pic18f2420_2321_MSG.txt
(3.43 KiB) Downloaded 234 times
Has thanked: 703 times
Been thanked: 768 times
Re: C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\PIC\batch\pic_xc8_comp.bat reported error code 0x1
The compiler message is stating
the PIC18 extended instruction set was enabled but is not supported by this compiler
You will need to go to the Project Options and change the configuration settings:
Extended CPU Enable
from Enabled to disabled.
While you are at it, if I was you, I would also change
Watchdog Timer
and
Low Voltage Programming
from Enabled to Disabled .
Check you have the
Oscillator
settings, set up correctly to match your hardware.
daddytims_tims
Re: C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\PIC\batch\pic_xc8_comp.bat reported error code 0x1_Solved
Goodmorning,
Thank you for your assistance, Martin
It compiled now
Thats Great!
Thank you for updating us.
daddytims_tims
Following up on the same Project,
There's another thing, I wanted to build a time crucial project,
I used the internal Osc Helper at 8MHZ, when testing the Led on the Breadboard The led Flash stays for 3sec on and 3 sec Off.
So therefore, the chip is running very Slow in real Life
Can This Be resolved?
Within Project Options..., did you set the clock speed to 8MHz as well?
If you did then if you upload your latest project, then I will take a look at it for you.
