I purchased version 10 today upgrading my version 8. I purchased pic8 and pic16
My machine has two drives c: and d:. I have installed v10 on drive D.
when loading tool chain for pic16 there is no option for selecting a Drive. I suspect the tool chain repair over wrote the PIC16 on drive C.
to over come the report unable to comply to C. I filled out and copied the pic16 from c: to d.
attached file locations
when I try to compile to hex i get an error message " you do not have a valid license"
I have activated my license.
It shows the three items I purchased pic8, pic16 and ARD
Luckily my v8 appears to still be working.
Can you help
Roy
cannot complie to HEX after installing V10 Paid licence
rsbake24ja
- complie error HEX .png (203.16 KiB) Viewed 8825 times
- Has thanked: 755 times
- Been thanked: 817 times
Re: cannot complie to HEX after installing V10 Paid licence
Sorry you are facing licensing issues.
We are investigating and will hopefully find out what the issue is ASAP.
Have you Refreshed your licence since activating your account with the key?
Then restarted Flowcode?
I'm assuming you have.
Help > Licensing > Manage > My Flowcode LicenceI'm assuming you have.
Hi Roy.
There was an issue with our sever, which has now been fixed.
Many thanks for reporting this.
Can you now please reactivate your licence within Flowcode
Help > Licensing > Manage > My Flowcode LicenceMartin
rsbake24ja
Hi All I can now compile but cannot make hex file .
The error seems to be
coff-gcc-exe:Files No such file or directory
NOT FOR COMMERCIAL USE
https://www.flowcode.co.uk
Using <PICkit4 IPE External Power> inbuilt settings for compiler
Launching the compiler...
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\PIC16\batchfiles\pic16_C30_comp.bat "D:\Program Files (x86)\Flowcode\Common\Compilers\pic16\\" "DSPIC33EV256GM002" "D:\Users\roy\Documents\Flowcode8\2024\" "33EV256GM002"
D:\Users\roy\Documents\Flowcode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
D:\Users\roy\Documents\Flowcode8\2024>REM REVISION: 2.0
D:\Users\roy\Documents\Flowcode8\2024>REM GUID: 7821ABE5-9E21-4744-81B7-3FF600B75DB7
D:\Users\roy\Documents\Flowcode8\2024>REM DATE: 25\03\2024
D:\Users\roy\Documents\Flowcode8\2024>REM DIR: FCD\PIC16\batchfiles\pic16_C30_comp.bat
D:\Users\roy\Documents\Flowcode8\2024>xc16-gcc -c -mcpu="33EV256GM002" -omf=coff -funsigned-char -fno-short-double -Os -I"D:\Program Files (x86)\Flowcode\Common\Compilers\pic16\\support\h" -I"D:\Program Files (x86)\Flowcode\Common\Compilers\pic16\\" -I"D:\Program Files (x86)\Flowcode\Common\Compilers\pic16\\batchfiles\" -std=gnu99 "DSPIC33EV256GM002".c -o "DSPIC33EV256GM002".o
coff-gcc.exe: Files: No such file or directory
coff-gcc.exe: (x86)\Flowcode\Common\Compilers\pic16\\batchfiles -std=gnu99 DSPIC33EV256GM002.c -o DSPIC33EV256GM002.o: No such file or directory
coff-gcc.exe: no input files
Error returned from [xc16-gcc.exe]
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\PIC16\batchfiles\pic16_C30_comp.bat reported error code 0x1
Autoclose turned off
rsbake24ja
I have changed location of compiler from
to
and get a new error
basically Options have been disabled due to restricted license
Target folder: D:\Users\roy\Documents\Flowcode 10
Source name: D:\Users\roy\Documents\Flowcode 10\DSPIC33EV256GM002.fcfx
Title:
Description:
Device: PIC16.33E.33EV256GM002
Generated by: Flowcode v10.1.1.39
Date: Friday, July 26, 2024 15:39:57
Users: 1
Registered to: XXXXXXXXXXXXXXX
Licence key: XXXXXXXXX
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\PIC16\batchfiles\pic16_C30_comp.bat "D:\Program Files (x86)\Flowcode\Common\Compilers\pic16\" "DSPIC33EV256GM002" "D:\Users\roy\Documents\Flowcode 10\" "33EV256GM002"
D:\Users\roy\Documents\Flowcode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
D:\Users\roy\Documents\Flowcode 10>REM REVISION: 2.0
D:\Users\roy\Documents\Flowcode 10>REM GUID: 7821ABE5-9E21-4744-81B7-3FF600B75DB7
D:\Users\roy\Documents\Flowcode 10>REM DATE: 25\03\2024
D:\Users\roy\Documents\Flowcode 10>REM DIR: FCD\PIC16\batchfiles\pic16_C30_comp.bat
D:\Users\roy\Documents\Flowcode 10>xc16-gcc -c -mcpu="33EV256GM002" -omf=coff -funsigned-char -fno-short-double -Os -I"D:\Program Files (x86)\Flowcode\Common\Compilers\pic16\support\h" -I"D:\Program Files (x86)\Flowcode\Common\Compilers\pic16\" -I"D:\Program Files (x86)\Flowcode\Common\Compilers\pic16\batchfiles\" -std=gnu99 "DSPIC33EV256GM002".c -o "DSPIC33EV256GM002".o
Visit http://www.microchip.com/ to purchase a new key.
DSPIC33EV256GM002.c: In function 'main':
DSPIC33EV256GM002.c
3: error: 'CLKVIDbits' undeclared (first use in this function)
DSPIC33EV256GM002.c
3: note: each undeclared identifier is reported only once for each function it appears in
DSPIC33EV256GM002.c
10: error: 'oscconbits' undeclared (first use in this function)
DSPIC33EV256GM002.c
25: error: expected ')' before '!' token
DSPIC33EV256GM002.c
2: warning: 'return' with a value, in function returning void
to
and get a new error
Title:
Description:
Users: 1
DSPIC33EV256GM002.c
DSPIC33EV256GM002.c
DSPIC33EV256GM002.c
DSPIC33EV256GM002.c
DSPIC33EV256GM002.c
Hi Roy.
It seems like your Flowcode is correctly set up now as the
That warning can be ignored as it just means if you paid for the professional version of the compiler, it will be a bit more efficient.
For the other errors have you done a full database update?
Help > Library updates... Change Files in-use to Full database then close and reopen Flowcode.
If you have updated and reloaded Flowcode after, can you upload your .fcfx project file?
basically Options have been disabled due to restricted licenseFor the other errors have you done a full database update?
rsbake24ja
Hi Martin
The compiler works OK in v10 but has stopped working in V8 for 16 PIC . Can they both sit side by side on the same machine or is this a license issue.
I wanted to keep both working.
- Has thanked: 300 times
- Been thanked: 465 times
The toolchain should work on both Flowcode v8 and v10. What is the error you are experiencing with v8?rsbake24ja wrote: ↑Fri Jul 26, 2024 8:57 pmThe compiler works OK in v10 but has stopped working in V8 for 16 PIC . Can they both sit side by side on the same machine or is this a license issue.
rsbake24ja
Hi Steve
I get the message "pic16 compiler toolchain is not installed Please visit......
I have tried reloading pic16 toolchain but I suspect it just overwrites the V10 location.
I tried directing the program directly to the Compiler in the option boxes of v8
$(compilerpic16)batchfiles\pic16_C30_comp.bat changed to V10 location.
D:\Program Files (x86)\Flowcode\Common\Compilers\pic16.
There is also the original version in the C: @ C: \program files (86)\flowcode\common\compilers\pic16\
I saw one message on the form suggest removing a registry entry. Still looking to find it again. It covered not using a compiler after installation and then uploading another.
Hi Roy,
To fix this, you will need to add an entry in the registry to point Flowcode v8 to the pic16 compiler toolchain. These instructions assume Flowcode v10 is correctly set to compile a pic16 project.
- Open Flowcode v10 and open File...Global Options
- Copy the entry for the PIC16 toolchain location in the "Locations" tab
- Open Regedit and create a new string value here:
--> HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\MatrixTSL\Flowcode\Common - The string value should be named "Compiler_pic16" and its value should be the same as the location copied from the v10 location in step 2 above
- Close Regedit and close Flowcode v10
- Open Flowcode v8 and create a new PIC16-based project and try to compile it
