who can help me compile to esp 32, everything is installed:
- python 3.12.5
- git version 2.46.0
- ESP toolchain found at "C:\esp-idf\frameworks\esp-idf-v5.3\"
compile message attached
esp32 compiler problem
charafi_hassan
- Has thanked: 1 time
- Has thanked: 177 times
- Been thanked: 1026 times
Re: esp32 compiler problem
You have spaces in the filename and path. Try saving as a new file without and see if that works.
charafi_hassan
charafi_hassan
Now I have this problem, please help me :
Done! You can now compile ESP-IDF projects.
Go to the project directory and run:
idf.py build
Usage: idf.py [OPTIONS] COMMAND1 [ARGS]... [COMMAND2 [ARGS]...]...
Try 'idf.py --help' for help.
Error: No such option: --no-hints Did you mean --no-warnings?
Programming Failed
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\ESP\Batch\esp32_prog.bat reported error code 0x1
idf.py build
Programming Failed
