STM32 Auto programmer ( via ST-link V2)
celebriums
Has thanked: 25 times
Been thanked: 13 times
Post by celebriums »
Warm greetings to everyone from Istanbul!
While developing or experimenting with STMCubeMX, I got tired of constantly configuring settings and uploading programs. To solve this problem, I developed the attached software, which I hope will be useful for everyone.
Simply put:
**Note:** You must have STMCubeMX installed on your computer. You can use the ST-Link V2 programmer, and I’ll share a picture of my version later.
When the software opens, it will look like the "Program Init" screen. The first step is to locate the STMCubeMX CLI.exe file.
### Step 1:
Click the "STMCubeMX Pro" button.
By default, the STMCubeMX CLI can be found in the following directory:
`C:\Program Files\STMicroelectronics\STM32Cube\STM32CubeProgrammer\bin`.
None of the other buttons will be active until you select the STMCubeMX program.
After selecting the STMCubeMX CLI.exe file, confirm your choice.
### Step 2:
Select the folder where your software's HEX file is located (*.hex) and confirm.
Once you make this selection, the program will upload your file once.
Afterward, every time you compile your program with Flowcode, this software will automatically upload it to your board.
Be careful when making the USB Programmer connections for +5V, SWDIO, and CLK.
Every time you press the "Reupload" button, the current software will be re-uploaded.
Since the program is approximately 36 MB in size, I will share it through a third-party website.
1 Program Inıt.png (40.6 KiB) Viewed 4109 times
Sadık Süme
celebriums
Re: STM32 Auto programmer ( via ST-link V2)
Other Pictures
Sadık Süme
celebriums
File load
3 STMCubeMXProgrammerCLI Choose.png (171.18 KiB) Viewed 4103 times
2 STMCubeMXProgrammerCLI.png (186.75 KiB) Viewed 4103 times
Sadık Süme
celebriums
Hex Load
4 Software Import.png (263.64 KiB) Viewed 4102 times
Sadık Süme
celebriums
Check Time Settings
7 Check Time.png (53.03 KiB) Viewed 4102 times
6 Program Auto Load Screen.png (79.51 KiB) Viewed 4102 times
Sadık Süme
celebriums
Program Link
https://www.mediafire.com/file/5duks1o4ghfughp/main.exe/file
thanks
Sadık Süme
mkopitovic
Has thanked: 1 time
Been thanked: 5 times
Post by mkopitovic »
thanks
work flawless
