I would like the integration in FC9
The part is quick and cheap
The MPLAB® Snap In-Circuit Debugger/Programmer allows affordable, fast and easy debugging and programming of PIC®, dsPIC®, AVR and SAM flash MCUs and MPUs, using the powerful graphical user interface of MPLAB X Integrated Development Environment (IDE) version 5.05 or later. The MPLAB Snap can be connected to a computer using a High-Speed USB 2.0 interface and can be connected to the target via an 8-pin Single In-Line (SIL) connector. The connector uses two device I/O pins and the reset line to implement in-circuit debugging and In-Circuit Serial Programming™ (ICSP™). It has all the speed and features entry-level users need to quickly debug their prototype.
The MPLAB Snap programs fast, with a powerful 32-bit 300MHz SAME70 MCU for quicker debug iterations. Along with a wide target voltage, the MPLAB Snap supports advanced interfaces such as 4-wire JTAG and Serial Wire Debug with streaming data gateway, while being backward compatible for demo boards, headers and target systems using 2-wire JTAG and ICSP.
Note: The Snap is compatible with MPLAB X IDE version 5.05 and later.
Sincerely
SpeedPic32
MPLAB® Snap In-Circuit Debugger/Programmer in FC9
SpeedPIC32
- Has thanked: 49 times
- Been thanked: 20 times
- Has thanked: 630 times
- Been thanked: 836 times
Re: MPLAB® Snap In-Circuit Debugger/Programmer in FC9
Many thanks for the suggestion. I've added details on how to use the Snap programmer to this page on our wiki.
https://www.flowcode.co.uk/wiki/index.p ... ming_Tools
SpeedPIC32
i wish for the debuger function in FC9.
thanks Ben
thanks Ben
- p.erasmus
- Has thanked: 104 times
- Been thanked: 88 times
HI
If you follow the instruction in V9 it will work in V9
this settings is not relevant to what version the example shows ,
just follow the instruction in V9
Ha OK I missed the debugger part sorry for my comment !!
The debugging functionality may only be available inside MPLABX.
You can take the C code generated by Flowcode and load it into MPLABX if you want to use the debugging.
Inside Flowcode we currently only support Ghost based debuging as seen on E-blocks and Flowkit hardware.
SpeedPIC32
Hello Ben,
is there an example or a tutorial video
