It may be a bug on my part.
The screenshot says "Compile Error".
I have included the V10 program.
Compile error for a do nothing program
Billduck1302
- Has thanked: 2 times
- Been thanked: 1 time
- Mega_LeafBatteryPackTrials.fcfx
- (18.34 KiB) Downloaded 438 times
- (view online)
- Flowcode Error.png (47.17 KiB) Viewed 11104 times
- Has thanked: 311 times
- Been thanked: 479 times
Re: Compile error for a do nothing program
I just tried this project and it compiled without error. Although I had to change the target device because Flowcode complained when I loaded it, saying the FCD file was missing or corrupt.
You should try updating your library files and make sure you are using a valid unmodified target device.
If you are still having issues, please post the .c and the .msgtxt files also as these may help determine what has gone wrong for you.
- Has thanked: 795 times
- Been thanked: 858 times
Just a pin not connected can be one of the causes of Syntax error
I loaded your project and for me it compiled without any changes or errors.
Perhaps you could run a full database library update, then reload your project and compile again.
Edit: Steve beat me to it, but at least there are two people now saying your project compiles OK
Billduck1302
A couple of questions.
1. I opened a known good program on an UNO, modified it and d/l it, and got the same error.
So I am thinking that the problem resides either with my computer or the software.
2. How do you update all library files?
3. What model of Laptop are you using? I am thinking of having a dedicated computer for Flowcode.
Billduck1302
The C code is too large of a file to post . Even for "Hello World"
Sorry. By "post" I meant add then to a reply here as an attachment. You can either drag the file(s) across onto the area you type in or can use the attachment tab.Billduck1302 wrote: ↑Thu Dec 12, 2024 7:19 pmThe C code is too large of a file to post . Even for "Hello World"
The C file should not be too large to be attached. The "Mega_LeafBatteryPackTrials.c" file produce when I compile your project is 101 kB and the "Mega_LeafBatteryPackTrials.msg.txt" file is just 8 kB.
If they are still too large, then you could zip them up and add the zip file.
The information in the C and MSG.TXT files should help us determine what the issue is and we'll know more when we can view them.Billduck1302 wrote: ↑Thu Dec 12, 2024 6:55 pm1. I opened a known good program on an UNO, modified it and d/l it, and got the same error.
It's on the menu bar under "Help...Library Updates..."
Flowcode does not need a particularly powerful computer or laptop to run. If it can run Windows 10, then it should run Flowcode fine.Billduck1302 wrote: ↑Thu Dec 12, 2024 6:55 pm3. What model of Laptop are you using? I am thinking of having a dedicated computer for Flowcode.
Billduck1302
The c file is attached.
- HelloWorld1.txt
- (71.17 KiB) Downloaded 412 times
Thanks. The syntax errors occur in the gLCD font routines. I don't know why this should happen though. Are your library files up-to-date?
Billduck1302
The library files are up to date. Thanks.
The only thing I know to do is to d/l FC 10 onto a new computer.
