PIC 8bit toolchain for FC9
jandidden
Has thanked: 28 times
Been thanked: 12 times
Post by jandidden »
After some hiatus back on a PIC 8 bit project with FC9. New PC and need to re-install the 8-bit toolchain.
The toolchain download page which is geared to FC10 says that the PIC8 toolchain for other than FC10 needs to be downloaded 'from the appropriate section on your account page' (link).
However, there it gives the same message - you need to download from the appropriate page bla bla.
I get dizzy from going around that loop ... ;)
Where do I find the toolchains for FC9 including PIC 8 bit?
Jan
Has thanked: 311 times
Been thanked: 479 times
Re: PIC 8bit toolchain for FC9
When you visit your account page you should be able to download the installer from the "download" dropdown in the "Flowcode 9" section.
jandidden
Post by jandidden »
Maybe I am stupid, but whatever I try, I end up here.
No FC 9 account page in sight, in none of the tabs.
Jan
Has thanked: 795 times
Been thanked: 858 times
Hi Jan.
Instead of Buy Flowcode top link, you should select Download top link.
If you are not logged in, you will be prompted to log in first.
jandidden
Post by jandidden »
I was stupid. Just found it, it's under downloads on the FC10 page....
As Martin said above.
Jan
For future reference, all toolchain downloads are also under the relevant Flowcode version on your account page as per this image.
