DFPlayer
bdjbuster
- Been thanked: 1 time
DFPlayer
Hello, I have an open smart serial control USB MP3 board, and I would like to control it with an Arduino Uno. However, I am unable to get it to work with the DFPlayer. Could someone take a look at what I might be doing wrong? Or is the board I have not supported? If it is not supported, could I get it working myself with UART communication?
- mp3 spelen test.fcfx
- (9.73 KiB) Downloaded 116 times
- Has thanked: 156 times
- Been thanked: 904 times
Re: DFPlayer
If it uses DFPlayer commands then it should work - files do need to be correctly named and stored too.
I recently got a batch that didn't seem to work (they were cheap Temu) See viewtopic.php?p=15950#p15950
and viewtopic.php?p=16175#p16175
Re: DFPlayer
I know the device works well because I uploaded a sketch using a demo of the Arduino IDE, and it works perfectly. However, I would like to use Flowcode instead. How can I check if my version is also supported? I have this one: https://www.tinytronics.nl/nl/audio/aud ... uidspreker
Re: DFPlayer
Looking at the datasheet it seems to have a slightly different command set to the dfplayer. The basic format of commands is the same though, so it wouldn't be a difficult task to modify the component to work with your board.
Matrix kindly make all the components open source - so you could take a look at that (or I can post the source to my component - which implements more of the dfplayer commands)
Re: DFPlayer
"Thank you for your response. I looked into the possibility of ordering a DSPlayer, and that could work, but they all only have a speaker output and no headphone output. I would like to modify the source code, but I’m not sure how to access the code or how to work with it. Could you explain how I can access the source code and how it works, or is there a document that explains this?"
Re: DFPlayer
The source for the FC component is at https://www.flowcode.co.uk/wiki/index.p ... io_Output)
The datasheet for the board is in the downloads page on the product link.
You can 'experiment' with the component easily - open it in FC and edit and test as a program. You'll need to check the pins etc are set correctly for your MCU - and then check initialise sends the correct data. Then test individual commands by calling SendCommand - which will write the header command and parameters to the UART connected to the player - hopefully resulting in some sound when you send 'play'.
An alternative is to load an an Arduino as a SCADA target and then you can run the program on the PC (in simulation) - whilst still sending the data to the board from the Arduino. This takes a little more setting up but is a very neat trick.
Have a play - I don't have the same board so it's difficult to test - but if you upload your progress we can take a look and assist if needed.
Re: DFPlayer
I managed to get it working. I eventually used a UART (CAL) under the 'Creation' section and sent the hexadecimal numbers one by one.
