TM1637 and pic 18F26K20
bercioiu
Has thanked: 13 times
Been thanked: 6 times
Flowcode v10 TM1637 and pic 18F26K20
Post by bercioiu »
Hello everyone!
I have a problem with a component, namely TM16537! I can't use it with pic 18F26k20 at 64 MHz. If I put another pic, for example 16F1938 at 32 MHz, everything is ok. What am I doing wrong in the configuration? Thanks!
contr_inc_2025_18F26K20.fcfx
(11.82 KiB) Downloaded 183 times
Has thanked: 794 times
Been thanked: 858 times
Re: TM1637 and pic 18F26K20
Configuration including OSCTUNE looks correct, so I assume pin A0 is toggling every second?
Try reducing the speed to 32MHz, then check to see if the display is working correctly.
bercioiu
Flowcode v10 Re: TM1637 and pic 18F26K20
Post by bercioiu »
It seems to be a problem with FC10, because I installed FC8 and is ok, everything works.
I also tried at 32 MHz but it still didn't work.
The LED is flashing correctly.
contr_inc_2025_18F26K20_fc8.fcfx
(8.47 KiB) Downloaded 187 times
That is really odd as I don't have the same target device as you, hence using 27K42, running internal osc 64MHz and works as expected with FC10.
Its not like the component is using I2C as the data and clock are bit banged
Do you have a logic analyser?
If can you compare the ck and data for both FC10 and FC8
bercioiu
Post by bercioiu »
Unfortunately I don't have a logic analyzer. I think the problem is from the setting of the delay between transitions, which is no longer in FC10.
Looking at your image for FC8, you have Display Type set to Cathode.
With the FC10 version, you have Display Type set to Anode.
Could that be the issue?
bercioiu
Post by bercioiu »
Yes, I tried several settings and I did a print screen at a random setting. Anyway, in FC8, it works even if I put common anode or common cathode, probably a component leak...
bercioiu
Post by bercioiu »
Same display, with two different hex FC8 :-)
