LP503x
rndmotecfi
Been thanked: 1 time
LP503x
Post by rndmotecfi »
Can you create an LP503x RGB LED driver component library ?
Attached is the component spec.
lp5036.pdf
(1.62 MiB) Downloaded 475 times
Has thanked: 647 times
Been thanked: 856 times
Re: LP503x
Many thanks for the suggestion yes that looks like a very interesting device and hopefully not too hard to implement.
I'll have a go for you and let you know.
Re: LP503x
This has now been added as a component in v9 for you.
rndmotecfi
Re: LP503x
LED control does not work. Can you tell me where the problem is.
I2C configuration or something else. HW has been checked.
CANBus works.
RGB_LED_LP503x1_test.fcfx
(14.23 KiB) Downloaded 434 times
