Martin Fisher great component Max7219_v2 a question Solved.
jgu1
Has thanked: 839 times
Been thanked: 205 times
Re: Martin Fisher great component Max7219_v2 a question Solved.
Post by jgu1 »
Hi!
I can confirm, a really good component Martin made for us, I still do projects with it for friends. Question for Martin, I understand you have made an update, pin connection, will this have any effect on my previous projects if I have to change something in these with the new Component macro, please :)
Thank´s in advance
Br jorgen
Has thanked: 163 times
Been thanked: 960 times
Post by mnfisher »
Hi Jorgen,
I never found out how to do an 'unconnected' properly - so you might need to set MISO to an unused pin for things to compile. I think there is an option to allow 'unconnected' - and as MISO isn't really used anywhere it would be better if it didn't need it to be assigned.
MArtin
jgu1
Post by jgu1 »
ok, thank´s Martin. But I notice last time I used the component when I add to to the 2D panel, first I see it and can see the properties, but as soon I do something it dissapear from the 2D panel and I can´t find it again, is there a way to see it again? ;)
Jorgen
Viktor74
Has thanked: 5 times
Been thanked: 4 times
Post by Viktor74 »
mnfisher wrote:
Thu Feb 13, 2025 11:45 am
Yes - if you get any issues I can try and help...
Hello!!! Could you please tell me how to install the MAX7219_v9 macro for Flowcode 10 under Atmega328P? During compilation I get the error C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\AVR\batchfiles\avra.bat reported error code 0x1
And also there is no component itself in the 2D or 3D simulation panel. I'm a beginner so maybe I'm doing something wrong. Sorry for the English, I work through a translator. Best regards, Victor.
Translated with DeepL.com (free version)
Post by mnfisher »
Installing the component is fairly straightforward - copy the '.fcpx' to a location (have a folder for components) - and point FC to this (build->customise->locations->look for components in). Add it to your code (you'll need to close / reopen FC)...
There is, however, no simulation / 2d / 3d panel presence - I wrote it a while ago and didn't know how to do this :-(
Not sure what therr from avra.bat is - have you set the com port etc?
Viktor74
Post by Viktor74 »
Hello! Could you please tell me, in the free version 10, I won't be able to add a component Max7219_v9.fcpx in the flowcode?
Has thanked: 724 times
Been thanked: 783 times
The other way is to select File > Global Settings... > Locations tab > Look for components in...
Viktor74
Post by Viktor74 »
Did I understand correctly and is this what it looks like?
Post by mnfisher »
Looks like it's there... Right at the bottom of the list - select and hopefully good to go...
Viktor74
Post by Viktor74 »
Yes, thank you, the link is at the bottom, but a simple code for clarity at compile time produces this error. Maybe someone has a simple code and can share it for clarity to be able to see how it works?
