ESP32 read I2C speed increase
Has thanked: 234 times
Been thanked: 252 times
Re: ESP32 read I2C speed increase
I have IDF Version: v5.0.6 ...
On another computer I have 5.31 and it's compiling and running there.
I'm now trying to read data from the my IMU
Has thanked: 163 times
Been thanked: 960 times
Post by mnfisher »
Did it work? Any benefits?
Hi Martin
Yes, it has improved,
but there is something extra at the end. I'll see what it is.
Do I have to start with FCD_ in the variables and take the definition out of the loop and put the variable definition at the beginning of the main?
It is very nice that I can set the clock to 1.2Mega
I assume that reading now only takes 120uSec, maybe a bit tight if I have to sample with 8Khz:)
Do you know how I can test this?
polling mode can help to reduce your 50 µs pause because it avoids the overhead of interrupts. If you want to test it, try portMAX_DELAY as timeout for i2c_master_cmd_begin()
Post by mnfisher »
Yes - it sort of trades the delay at the beginning for one at the end.. A little quicker though..
Could use FC variables - local start with FCL_ global with FCV_ (capitalised name too)
Hi Martin
I have additional measurements with FC10 and a PIC32 and with an ESP32 but with a Python compiler.
So Flowcode seems to work well.
I guess it's time to look at I3C
From a microchip PIC32MZ2048 and FC10, with two breaks:
From an ESP32 and Python compiler, mega long long time break... :)
Post by mnfisher »
It is odd isn't it...
Is maybe an issue with the transactional nature of i2c (I suspect none of the above support direct control of the i2c using Start, Stop etc - but it might be fun to try a chip that does)
Is there an SPI version??
I'm still looking at an STM32F405
Yes I have a spi version of the chip
Post by mnfisher »
That should allow a faster read rate - hopefully. The gyro might have a maximum update speed?
Hi Martin
Yes Accelero and Gyro can be used with 8kHz.
A problem is the size from the spi version, I2C is much smaler
and the I2C version is reaydy to use with I3C.
So I test first with the spi version an hope I3C with Flowcode will follow soon.
I will simply change the component Gyro_L3GD20 ( spi)
Size from both:
Post by mnfisher »
The esp32-p4 should support i3c.
Flowcode (v11!) too?
