how to turn led on off using +1 counter and -counter
KJWILLOTT
Post by KJWILLOTT »
hello i have led display two counters for counting numbers up and down works ok i would like to turn on four seperate led when the counter increases
i have used 4 decisions in the code each set one higher than the other >=1 >=2 >=3 >=4 this works tried to do the same on the down side when the counter is -1 then i used decision code <=-1 <=-2 <=-3 is their unother way to turn led off using counter -1 can any one help please many thanks
Has thanked: 768 times
Been thanked: 828 times
Re: how to turn led on off using +1 counter and -counter
If you post your current project,
We can then help you further.
You also need to state what version of flowcode you are using.
KJWILLOTT
Post by KJWILLOTT »
https://1drv.ms/u/c/8721757fd931cd25/Eb ... Q?e=RDF3x6
This is project how to turn led on off using -1counter and -counter right button increasing count up and turn s 4 leds on each in turn . left button turns counting display down ( problem ) turning 4 led s off in turn using decisions icon and a minus counter
hope you can help many thanks Kevin chart from version flow code v 10 free
Has thanked: 177 times
Been thanked: 1016 times
Post by mnfisher »
Better to attach your chart to the message (Full Editor & preview -> Attachments (below edit window) -> Add files) or drag and drop the file!
There are many ways to do this - I did a very simple demo - that uses an array of LEDs and using consecutive pins (select port mode in properties or set the individual pins)
So - I use the fact that to light the relevant LEDs I can write 2^n-1 to the port (so 0 leds -> 0, 1->1 2->0b11, 3->0b111, and 4->0b1111)
leds.fcfx
(13.56 KiB) Downloaded 157 times
I have edited your post as caps is seen as shounting .
Please don't do that again.
The issue with your project is you used decision branches with negative values e.g If:count >= -2
Count variable is a byte = 0 to 255, so it will never be a negative value.
Therefore all the decision branches with negative values to compare will always be false.
I have modified your project.
turntable complet no 9-with lights v2.fcfx
(40.28 KiB) Downloaded 147 times
KJWILLOTT
Post by KJWILLOTT »
hi martin thank you for your skill and time helping with my project much appreciated did not wish to offend
thank you again for your quick response very helpfull kev
