BH1750 ligth sensor!
jgu1
Has thanked: 839 times
Been thanked: 205 times
Flowcode v10 BH1750 ligth sensor!
Post by jgu1 »
Hi!
Just started a new project with a BH1750 ligthsensor. As soon I try to compile to hex I get an error, look like it is the initilise. What am I doing wrong, please?
Br Jorgen
Ny_Fiskedam.fcfx
(15.65 KiB) Downloaded 112 times
Has thanked: 724 times
Been thanked: 783 times
Re: BH1750 ligth sensor!
Hi Jorgen.
It looks like your DVI pin is not set correctly.
Try setting the DVI pin and compiling again.
jgu1
Post by jgu1 »
Hi Martin!
Thank you, very much, I continue in the afternoon, and check ;) You hear.
Br Jorgen
jgu1
Flowcode v10 Re: BH1750 ligth sensor!
Post by jgu1 »
Hi again Martin!
You are rigth, it was the DVI pin. I always forgot to check the pin everytime I add a new component, it work now.
Thank you :D
Br Jorgen
You're welcome.
I'm glad you are up and running.
For future reference.
Depending on the device if a pin is not connected then you could see two types of errors.
Most devices would show a tris error , which yours did, that how I knew it was a pin not connected.
I have noticed that ESP32 could just show syntax error.
jgu1
Post by jgu1 »
Nice tip Martin, great. ;)
Thanks and have a nice weekend......
