ESP Compilation error.help me please!
Been thanked: 3 times
Post by 17712885438 »
ESP32 Compilation error.txt
(5.97 KiB) Downloaded 371 times
Has thanked: 773 times
Been thanked: 833 times
Re: ESP Compilation error.help me please!
Anyone that has compile error would save time by proving the .fcfx, .msg.txt & .c files as it saves us asking for them.
My suggestion is test your toolchain set up by compiling using a Lolin32_lite target.
just create a basic test project, e.g. add a loop then within the loop, Output gpio 0 high, Delay 1 second, Output gpio 0 , Delay 1 second.
It does not matter if you don't have a lolin32 target device as you are only using compile to hex and not compile to target.
If compiles OK then we are looking at a esp32 C3 issue, so we will require all requested files.
If the Lolin32 does not compile to hex then we need to deal with that first.
Can you let me know the results, please.
Lolin32_lite targe Compilation error.WHY?
(184.91 KiB) Downloaded 374 times
Lolin32_lite target Compilation error.
Lolin32_lite target Compilation error.txt
(184.91 KiB) Downloaded 372 times
I can see a couple of issues with the ESP_CAL_String.c
%ProgramData%\MatrixTSL\FlowcodeV10\CAL\ESP
Place the attached C file.
If you run any library updates, then the ESP_CAL_String.c you added will be overwritten, so it will stop working again (unless the ESP_CAL_String.c update has been pushed).
The reason I asked to check with Lolin is because C3 is a new device, so wanted to make sure everything on a well established device.
ESP_CAL_String.c
(47.65 KiB) Downloaded 345 times
I did it your way, and it still didn't work.Please help me。
ERROR.txt
(5.85 KiB) Downloaded 386 times
17712885438
Lolin32_lite target is ok! but ESP32-C3,ESP-C6 still Compilation error.why?
For us to help you can you provide your .fcfx project file and updated .msg.txt file.
Without both files we won't be able to help.
Thank you very much. I have attached the documents and reports. Please help me.
C3.fcfx
(7.1 KiB) Downloaded 414 times
C3.txt
(5.93 KiB) Downloaded 417 times
Thank you for the report, we will add it to our list.
I have moved the topic to the bugs section.
