How to use StringInit Component to push a value in ROM ?
Nico595
Has thanked: 20 times
Been thanked: 5 times
Flowcode v10 How to use StringInit Component to push a value in ROM ?
Post by Nico595 »
I need to push user value in a ROM array to save mqtt username and password in the C code. I tried with StringInit Component but when I push a new value in "Str0", this variable is not saved when I restart the Pc App.
This function is it possible without design a txt file ?
1 - I set the box with the Str0 string.
2 - I enter a new string and save in Str0.
3 - I read the string from Str0.
It's ok, I have my new string in step 3 but the new string is lost if I restart the Pc App. I start with the string of step 1, registered in the Str0 parameter.
Capture d’écran 2025-05-09 134918.png (156.55 KiB) Viewed 7379 times
Thank you for your advices.
Has thanked: 724 times
Been thanked: 783 times
Re: How to use StringInit Component to push a value in ROM ?
If you want to use properties to store and load values, then you can use the Property Manager (Component Libraries > Storage > Utility).
It will crate a file for you, so all the hard work is removed.
Alternatively, if you attach your project, I can see if there is a better way of achieving desired results.
Nico595
Post by Nico595 »
Hello Martin,
It's probably a perfect tool to save the variables in a .cfg file but have you an example or a method ? What is the good syntax to use the RegisterProperty Function ?
The config.cfg file is not wrote with a Save.
Capture d’écran 2025-05-09 181335.png (40.56 KiB) Viewed 7314 times
Thank you :)
If you attach your project, I will see what I can do with it.
Nico595
Post by Nico595 »
I finally used the CSV Read Write Component to save and read variables in a config.cfg.
As this data content is password and username, I will encrypt the data before the save.
Thank you for your help.
