FC10 FILE NOT COMPILE AFTER UPDATE
SILVESTROS
Has thanked: 32 times
Been thanked: 2 times
Post by SILVESTROS »
Dear Sirs ,
After a library update, a FC10 file (WFSR1-18F47K40-FSX2), not compile..From this file I was get .hex file before , but now I get error as below...
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_String.c:871:: error: (712) can't generate code for this expression
(908) exit status = 1
Error returned from [xc8.exe]
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\PIC\batch\pic_xc8_comp.bat reported error code 0x1
I use FC10 V.10 .1.2.40
what is the reason for no compile ?
Thanks in advance.
Basil
WFSR1-18F47K40-FSX2.fcfx
(28.49 KiB) Downloaded 172 times
Has thanked: 772 times
Been thanked: 833 times
Re: FC10 FILE NOT COMPILE AFTER UPDATE
Can you follow these instructions.
That should sort you out until an update is available.
