Be brave.
Backup first!
Will always need to press reset though - it's also possible to program the esp32 using a ftdi connector - but it's a while since I tried this with the esp32-cam boards. I might have a play with another board and see how it works...
Esp32 S2 Mini Wemos v.1 not compile!
- Has thanked: 177 times
- Been thanked: 1016 times
karthickefy
Re: Esp32 S2 Mini Wemos v.1 not compile!
Hi Jorgen/Martin,
Have you fixed this error? I'm also facing the same issue. In my case, my ESP32-S2_mini board doesn't have a reset switch. Please advise. I have attached the schematic and compile error log for your reference.
Thanks,
Karthick
Thanks,
Karthick
- ESP-S2-Mini-1U chip programming error.txt
- (17.44 KiB) Downloaded 408 times
- Indus Board Schematic.jpg (127.52 KiB) Viewed 7387 times
I think the log file shows that the file uploads correctly - but can't reset the device..
Leaving...
WARNING: ESP32-S2FNR2 (revision v1.0) chip was placed into download mode using GPIO0.
esptool.py can not exit the download mode over USB. To run the app, reset the chip manually.
To suppress this note, set --after option to 'no_reset'.
See notes above about trying the no-reset option.
Leaving...
karthickefy
Thank you for your comment. Is there a way to add a soft reset to the script? As I explained, my board does not have a hardware reset switch.
Actually, I couldn't find the --after option in the esp32_prog.bat file. I'm not sure how to set the "no_reset" after --after.
below, I attached the esp32_Prog.Bat file (Changed to TXT format)
Karthick.
Karthick.
- esp32_prog.txt
- (1.94 KiB) Downloaded 539 times
jgu1
- Has thanked: 887 times
- Been thanked: 216 times
Hi both!
I used a capacitor, it work for me, reset after 2-3 sec. after power up the device if this is ok. I am not home at the moment, I come back when I come back.
Jorgen
Jorgen
After some playing the easiest way to not attempt reset is to go into the menuconfig (by running menuconfig.bat) and go to Serial Flashing->After Flashing and change to 'stay in bootloader'
... and Jorgen's tip is excellent - you need to add the capacitor to pull the chip into bootloader mode too.
The bit I added just stops FC reporting a failure (hopefully?)
karthickefy
Yes, I tried your method using menuconfig.bat, and the log file didn't show any errors now. I have attached it for your reference. However, after loading the firmware, the USB is not detecting, and the ESP32 fails to boot. The Flowcode file is also attached for your reference.
When I use this ESP32-S2 Mini board in Arduino IDE, I enable 'USB CDC on Boot" . It is working fine with Arduino.
I'm using this "https://indus.electronicsforu.com/" Indus coin rev2 board.
I will also try to add a Capacitor and see
For your information: I encountered this issue only with the ESP32-S2 Mini chip. I tested it with the ESP Wroom 32, and it worked fine.
Thanks for your timely response.
Karthick
Karthick
- ESP32-S1-INDUS-BLINK.fcfx
- (8.94 KiB) Downloaded 614 times
- (view online)
- ESP-S2-Mini-1U chip programming log.txt
- (162.23 KiB) Downloaded 466 times
