DMX master, can't get it to output (FC8)
beneee
Has thanked: 1 time
Re: DMX master, can't get it to output (FC8)
Post by beneee »
viktor_au wrote:
Thu May 29, 2025 12:07 am
Hi beneee
As I understood you have a project in FC8 to build a DMX controller.
I checked the FC8 comm components. Dmx library is for slave only(?).
Hi Viktor,
Thanks for the Info but I can assure you that both the DMX 512 Master and Slave are in fc8, unless of course the master has been removed as there is an issue with it since I downloaded the program - unsure how to check that.
Ben
Has thanked: 442 times
Been thanked: 661 times
Post by chipfryer27 »
I have both Master and Slave on my v8 however (and this is just a guess) up untl v10 you had to buy component packs and you had CommsA / CommsB / CommsC so perhaps Slave and Master are in different packs?
Pretty much irrelevant now as ALL are free to use in v10.
viktor_au
Has thanked: 11 times
Been thanked: 19 times
Post by viktor_au »
I think this is the case.
I have only slave.
viktor_au
Post by viktor_au »
An interesting discussion is here
https://forum.arduino.cc/t/arduino-as-a ... ler/377110
Did you try Arduino IDE?
DMXSerial
beneee
Has thanked: 1 time
Post by beneee »
Ok, just tried it with FC10 and get the same result i.e. really flaky intermittent receiving of the DMX signal on the fixtures.
Can anyone please share a working bit of code that sends out a continuous DMX signal that is constantly changing as from looking at the output it seems that when I update a value it screws the SendDMX macro.
If I have a known working bit of code it would be so helpful.
Please please help me
Ben
