TOF_VL53L0X Error
Has thanked: 442 times
Been thanked: 661 times
Re: TOF_VL53L0X Error
Post by chipfryer27 »
Hi Jorgen
Just curious, what accuracy were you getting and at what range?
jgu1
Has thanked: 839 times
Been thanked: 205 times
Post by jgu1 »
Did not test that, only see that it work and the value is changing by moving my hand in front of the sensor. Just close all down :( Made a new test tomorrow and you hear :D
No need to go to any trouble, I was just curious that's all.
I my tests I found that the percentage error was pretty consistent but within groups of ranges. By that I mean that between range a-b it would be x%, range c-d would be y% and so forth.
I could not reach anywhere near two metres though.
Post by 17712885438 »
Could you send a VL53L0X photo? Let me see if the Sensor model are the same? Thank you very much!
jgu1
Post by jgu1 »
Send some picture tomorrow, not home at the moment ;)
jgu1
Post by jgu1 »
I am went home ;) So hereby the picture, both working, but I have not testet the distance and accuracy.
jgu1
Post by jgu1 »
Just went home ;) Hereby a picture, both working in FC10 I have not tested the accuracy or distance. but Chipfreyer has. Hope it help. :)
Jorgen
Could you send me the database RangeTOF_VL53L0X.fcpx? thank you.
If you mean what my results were, I have already posted them in the forum.
Do a search for VL53L0X and you will find tbem.
My database of RangeTOF_VL53L0X.fcpx might be mistakes.Could you send yours database of RangeTOF_VL53L0X.fcpx to me.Thank you very much.
