Absolute ABS Function for Integers?
jay_dee
Has thanked: 97 times
Been thanked: 68 times
Post by jay_dee »
Does FC have an ABS ( Absolute ) function?
I have a current sensor and get both positive and Negative Values.
Is there a Calculation Function that will always return positive Value. I thought C had an ABS function.
If the Float Abs function is used, the compiler throws an error.
thanks, J.
Has thanked: 392 times
Been thanked: 603 times
Re: Absolute ABS Function for Integers?
Post by chipfryer27 »
Are you supposed to be getting negative values, which would suggest a reversal of flow?
jay_dee
Post by jay_dee »
Hi, Yeah absolutly. It is a H Bridge driven DC motor. I use the current to define the 'Clamping' force and hard limits of the driven assembly. J.
OK, just curious.
I assume you are getting a 2's compliment return?
If for example x = -27 could you not use x = fabs(x) to give 27 ?
PS
The above simulates but can't try compiling to hex yet as I need to install the compilers on this little machine I'm using
jay_dee
Post by jay_dee »
Ahhh.... Fabs(Value) this will not pass
but fabs(value) will pass the compiler.
it was not a problem with the function but with my capitalisation! doh!
FC usually lets me play fast and loose with capitalisation but not in this case!
Thanks. :)
OK...back to fixing the bigger project!!
Haha
Many times I have been caught out similarly and spent way, way too long chasing..... :)
Glad it is working now
jay_dee
Post by jay_dee »
appologies to the FC team, I think it might have been a even more basic mistake and not the capitialisation....
REVERSE...REVERSE...back away from the situation!!! haha!
Disengaging Panic Circuits...???
