Error copile
ELECTRONICA67
Has thanked: 31 times
Been thanked: 9 times
Flowcode v10 Error copile
Post by ELECTRONICA67 »
please could you check the following error that flowcode shows me when compiling, I am using the PIC16F1939.
^ (103) #error: "I2C Channel 2 does not have the SSP2IF defined on this chip - does your chip support this feature?"
ELECTRONICA67
Re: Error copile
mensaje
ELECTRONICA67
Flowcode v10 Re: Error copile
I'm using I2C Master for RTC and also LCDI2C Software
Has thanked: 163 times
Been thanked: 960 times
Re: Error copile
Post by mnfisher »
It looks like the PIC16F1939 only has one MSSP module - so only one hardware i2c channel?
Try using the software channel?
Has thanked: 442 times
Been thanked: 661 times
Re: Error copile
Post by chipfryer27 »
Without seeing your chart it looks like you are attempting to enable an Interrupt on Synchronous Serial Port #2 with the chip only supporting SSP on #1. As far as I am aware, FC only has Channel-1 and Software options, no Channel 2 for that chip.
Re: Error copile
I see Martin beat me to it..... He must have the datasheets open beside him...:)
ELECTRONICA67
Re: Error copile
Hello, I see... I think I'm still asleep !!!!! Thank you very much for the observation, Martin.
Best Regards
Enrique
Re: Error copile
Post by mnfisher »
Does anyone read anything else?
No problems sleeping for me :-)
It might be the fcd is incorrect if it allowed you to choose channel2?
Re: Error copile
I find "Practical Electronics for Inventors" an exciting read not just for bedtime but holiday sunbed too. Of course if you want glossy magazine racey, you could do worse than Practical Electronics (where there are adverts for exciting things to buy such as FC) and Elektor (which in my head I read as Goldmember from Austin Powers).
Sleep helps with cognative skill so surely Cognac at bedtime will turbocharge the experience?
Whilst you were busy beating me to replying, by sneakily have the datasheet open, I opened up FC and was only allowed Channel 1 or Software, so maybe Enrique needs some turbocharged sleep :)
ELECTRONICA67
I have to say that I prefer a glass of tequila (Agavero), the drawback is that you forget what you were doing. . . . :lol: but in a previous version of Flowcode I had an RTC connected on channel 1 and an LCDI2C display in software, and it compiled correctly, I'm using the same PIC16F1939; but with another update that was installed, that error stopped appearing, now only too many "warning".
I also added a 4x4 keypad; When you finish the program you save it, but when you open that same program the connections made on the keypad are changed to B0, B1, B2, B3, B4, B5, B6, B7
And again on another Laptop that I have not yet updated Flowcode, no error or warning is generated. :D
Best Regards
