I try to create a procect with an Arduino an a KS0108 display. The display show some strange sign. I have checked the wiring many time and change the display but same result The sign is moving so something happend.
Am I doing something wrong please?
Br Jorgen
KS0108 display + PZEM-004T!
jgu1
- Has thanked: 839 times
- Been thanked: 205 times
- IMG_0414.jpg (128.55 KiB) Viewed 4475 times
- PZEM DCAC.fcfx
- (22.59 KiB) Downloaded 382 times
- Has thanked: 724 times
- Been thanked: 783 times
Re: KS0108 display + PZEM-004T!
I have checked your project on a Uno and the KS0108 is working as expected. Since it works on the Uno, there is no reason for it no to work on the nano.
The issue you see with the display is either a wrong data connection or Open/Short.
With the power removed it's worth checking each pin of the display is connected to the correct pin of the nano using a DMM
jgu1
Hi Martin!
Many thank´s for wiring up and testing my program
At least I am glad it work by you, then I know I do something wrong.
It is strange, because I have checked all connection several time and also a new display. I test with a LCD display it work and your PZEM component also, perfect.
I am always full update with FC.
I will check again, if I not manage I will test on an Uno.
You hear, thank´s
You hear, thank´s
jgu1
Hi Martin!
You were right Martin. Two of these cheap jumper wire have bad connection, after replacing them, the display works perfectly.
Once again, thank you very much for your help
Br Jørgen
Br Jørgen
Hi Jorgen.
I'm glad you managed to resolve the issue, well done.
I have had O/C jumper wires before, So I feel the pain.
Thanks for keeping us updated.
